Hi Autodesk,
Can you add an option to Copy Design window where you can specify the number of copies you want to make of a specific file? With the bonus of having the name of those copies taken from an Excel sheet?
For example, if you have a master Window Model and want to make ten copies of that window and change the size or properties slightly. Right now, we have to do 'Copy-Design' 10x; doing all ten copies at once would be nice.
The problem of being unable to do One-To-Many copies is significant if you have a large project where you need to make 100x copies of the same file.
I appreciate your consideration.
-FR
