Copy Design, Replace first "x" amount of text
Hi all
I have seem many request for better file renaming within "Copy Design", this request is to add the renaming functionality.
It would be good to be able to replace a selected string length, within a name, with a new set of text.
My example is as follows:  The first 5 characters of my file name are a code linked to the specific internal project number for the design.  If I want to copy designs from various internal projects for reuse in a new project I need to replace the first 5 characters with a new text.
eg.
Project 1 code = 12345
Parts:
12345-abcd
12345-efghi
12345-jklmn
Project 2 code = xx12x
Parts:
xx12x-12345
xx12x-67891
If I run a rename of just the first 5 characters I can rename all the parts at once to have a new project number, instead of having to do a replace all for each project code copied from.
What would be nice is to be able to specify a seperator (in this case "-") and replace all text before it.
Use of wildcards would also help.
4 Comments
ihayesjr
Status changed to: Accepted
olearya
Hi Carl,
Please test this again in 2015 R2 version of Copy Design - we have changed file numbering to include auto numbering schemes and the "none" file numbering scheme allows you to find and replace text strings.
We do not have a "replace first 5 characters" type rule but a wildcard "Find *-" will work.
olearya
RonnieWilkins
Why not implement Regular Expressions for search/replace?
