Show only
Search instead for
Actually you can solve this by some configuration. After your first use of Autoloader, there will be a file named BUU.xml in your root folder, it is hidden, so just turn on "Show hidden files" in your vault option, then you can modify this xml file to set your folder configuration for Autoloader:
However, the solution is somehow cumbersome, it requires you set a library folder and it requires your workspace folder name same as your ipj file name.
The ipj is needed for other Vault functions after the files are added to Vault. If you already have an ipj in Vault, wouldn't you use it to load the other files using the Autoloader?
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
