I started using the Autodesk 360 Sync folder as my vaults working folder which works well for me. I would like the ability that when a file is renamed in Autodesk 360 and syncs back to my local sync folder, that Vault knows Autodesk 360 renamed the file. I know this is possible because if you rename a file now using Windows Explorer, Vault will give you message in Inventor that says "The file has been renamed or moved to a new location"
