Allow the vault to map custom properties of PDF files
I want to keep PDF files in the vault but also use custom properties.  Currently, you cannot do that.  See below from customer service:
I was able to confirm with development that this is working as design. As Vault does not have a dedicated IFilter for pdf files to map customer properties. To request this feature be added to Vault please post in the Vault Idea Station.
I did test a 3rd party IFilter, this adds a few more property options but does not add custom pdf properties. This behavior works the same in Vault 2016 and 2018.
34 Comments
Cela devient urgent que Vault travaille en collaboration étroite avec les PDF.  PDF direct ou issus de la CAO ou d'Office.
ihayesjr
Please review the Ideas Guidelines.
@ihayesjr
I've asked for the state, reading guidelines doesn't really help?
ihayesjr
The state is:
Future Consideration: While we’re generally a fan of these ideas, the timing isn’t quite right for development consideration. As such, they are being put on the back burner to be re-visited at a later date. Please continue to comment and add your support.
tim_gladdy
This is a requirement for our business also
mschindler-mum
users wish to have the availability that the properties can be included in the published PDF file when they publish it.
So non CAD-users in the network can found the properties inside the PDF document, similar to the iProperties from Inventor.
See the following markup image as an example where the Vault option could be implemented in a future Vault release.
Kind regards,
Matthias Schindler
CAD/CAM/PDM technical specialist at
tim_gladdy
This looks a good solution to me, thank you
kimjones4110
This would be a great feature! We use Bluebeam Revu and I can create custom properties for the PDF files. I can't map them in Vault though. We keep our PDF files for drawings in Vault. This seems like a basic function that should be available. Please add asap!
ihayesjr
Status changed to: Accepted
ihayesjr
WouterBreedveld
The PDF option is not available as property provider on my system. Both using 2024.2 and 2024.2.1
Do I need to do/configure something to make this active?
ihayesjr
@WouterBreedveld
You should see it listed here.
WouterBreedveld
@ihayesjr
Yes, that's what I was expecting but it isn't showing up.
Both server and client are on 2024.2.1
ihayesjr
@WouterBreedveld
Please create a support case for the issue.
