Add 'Review' option to Lifecycle Control tab & Thin Client
This is needed so companies can share files via the Thin Client (using an FQDN) which aren't released, but are out for review with the client.
Currently the only option in the Thin Client is to show released or all file versions and it's a Global administrator setting, rather than a user/groups based option. This limits companies ability to share & hide the files they need to.
10 Comments
well said , I concur on this much needed. thin cleint should not be only viewed for release of files much more of a collaboration if we can share via thin cleint.Smiley Happy
ihayesjr
Status changed to: Under Review
Great idea! Thanks for sharing.
aspex717
I probably need time to consider the implications around making information available while it is not released, as it could result in parts being manufactured prior to release. Perhaps a big red watermark showing the non trleased state (eg Work in Progress, For Review, Obsolete etc).
scottmoyse
@aspex717 good point. With this proposal, you would be able to turn off that feature across the board. I would have to check to see if it has been re-implemented, but Item DWF's do have State based Watermarks. However, in the last release they weren't showing up in the Web/Thin Client anymore.
heelo
i am using auto acd civil 3d ...2011
after installtion its not in english language its i cons and interfarence is in other language like russian
plz tell me how to chang it into english language
regards
fiaz
waiting your answar
 digitizerstime@gmail.com
mikel_martin
Couldn't you acomplish this by a Lifeycle state and security settings for that state?
scottmoyse
@mikel_martin no, not when Released files & Items are checked as well.
Steve_Bahr
You can batch plot the idw to pdf and specify a watermark of the idw's current state.  Not the best, but it works.
ThomasRambach
With this idea, all need ability for Change Order reviewers to review/approve an ECO from the thin client.
ihayesjr
