How can I create a saved search for the criteria.
- Any file in the vault thats not assigned a life cycle.
Hi C1,
One way, under the advanced find set your critera for Lifecycle Definition is Empty and File Name is not emtpy - then save it.
See attached image.
You actual saved search will be under :: C:\Users\Administrator\AppData\Roaming\Autodesk\VaultCommon\Servers\Services_Security_###\%ServerName%\Vaults\%Vault%\Searches\%SavedSearchName%
in case you want to copy it to other user profiles / workstations.
