Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error: The file is outside the defined search paths (when checking into Vault)
5 REPLIES 5
fsdolphin
2000 Views, 5 Replies
I have been trying to check-in a presentation into Vault and I keep getting the following error.
Has anyone seen this error before? Any idea wha needs to be done?
The assembly checks in fine. This is what I see in the Model Browser (tree) but I have no clue what the 3rd Party (plastic_Smooth_bump.png) is
Any help will be appreciated.
Thanks a lot.
5 REPLIES 5
fsdolphin
in reply to: fsdolphin
Have anyone seen this error before? Thanks
olearya
Hi There,
This is an Inventor issue.  The initial message indicates that the reference to that material is not detailed in your project file support paths (workspace, library etc).  I would suggest moving that to one of these locations.
Hope this helps.
Allan
Product Manager
Autodesk, Inc.
olearya
in reply to: olearya
Note that the bitmap is a material being referenced - you can also try to just remove it...
Allan
Product Manager
Autodesk, Inc.
fsdolphin
@Employeeolearya
How can I remove it? This is not something I intentionally added to my assembly or presentation, it just showed up on the tree.
Thanks a lot for your help.
olearya
There should be an option to delete the link - try:
Tools > Options > Links command
Allan
Product Manager
Autodesk, Inc.
