Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error migrating from Vault Basic 2013 to 2015
5 REPLIES 5
la
436 Views, 5 Replies
We've been running Vault Basic 2013 like forever (we've been 2 busy to upgrade) but now finally we were to upgrade it. I've read several times how it is possible to skip one version, like going from 2011 to 2013 so I thought it would work like a charm. But unfortunately no 😞
The installation of the Vault Basic 2015 is not a problem, only after when the Data Management Console is started, and it tries to migrate the databases, it fails.
The error is: Migration of 'databasename' failed: 'FK_BOMComponentProperty_BOMComponent' is not a constraint. Could not drop constraint. See previous errors. Would you like to migrate remaining databases? Selecting 'No' will stop further migrations.
I have created a support ticket with Autodesk but still no answer - and I have 5 colleagues sitting waiting for the Vault to be back up and running before they can work again. It's been 2 days now :S
I've come across this thread http://forums.autodesk.com/t5/vault-general-discussion/vault-server-2014-to-2015-database-migration-... which is similar however not exactly the same. In that case the problem was addressed in a hotfix (and later also in the SP) - it was a delete statement that failed.
I then thought I would try to upgrade just one version, to see if that would work. I rolled back to 2013 and installed 2014 and tried to migrate my 2013 to that, but another error occured: Migration of 'databasename' failed: There is already an object named 'ADMS'VacuumRestriction' in the database. CREATE SCHEMA failed due to previous errors.
I'm running virtuel so I can go to the installation of 2013, 2014 or 2015 I have created as needed - so whether I get the 2014 or the 2015 running, it would still be considered progress 🙂
Anyone with a good idea?
5 REPLIES 5
minkd
in reply to: la
For problems like this, you should open a Product Support case.  While you are waiting for a response, make sure you have the latest updates for 2015 installed.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
la
in reply to: minkd
Thanks minkd, but as I wrote in my thread I have already created a ticket :
I have created a support ticket with Autodesk but still no answer - and I have 5 colleagues sitting waiting for the Vault to be back up and running before they can work again. It's been 2 days now :smileyfrustrated:
I have tried with both a clean Vault Basic 2015 and with Vault Basic 2015 SP1 as suggested in the thread I linked, before starting the database migration. Same result.
Do you know how long it usually takes before a ticket is answered?
/Louise
minkd
in reply to: la
I have no idea - I have no insight nor influence on the inner workings of Product Support.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
la
in reply to: minkd
Well I can tell you to not expect it to be fast - so far I've waited 8 days and 9 hours without as much as a reply. I don't know what to say....
la
in reply to: la
13 days, serious? No reply, no nothing. Why offer the option to create support tickets when you never answer the customer, Autodesk?
Oh well never mind, I guess we'll have to keep using the Vault 2013 then. A bit of a shame that we just renewed our subscribtion. Smiley Sad
