While running Autoloader, I am unable to map to any folder other than "Designs". Is this the designed behavior?
I do not have a "Designs" folder in my Vault....
You may try the following solutions.
1. You can rename "Designs" to any name by right mouse click > Rename
2. If the about does not work then, you can try the following.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9480434&linkID=9261340
TS1068287
Madhan
I have been told that solution is for a previous release....
I understand that editing the xml is not easy for every user.
So, I created a utility for you to help mapping the folder to any folder. Please find the attachment.
Madhan
Do you have an updated version of this code for 2015?
