Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Who can have access to Vault Basic
acclarkJR2TJ
Message 1 of 13
acclarkJR2TJ
I have used Vault Basic off and on for several years, and the company is talking about using it.  But one of the main questions is:  Who can have access?
For example:  We have a support group for our systems, and sometimes they need access to drawings, but they don't have an AutoCAD license because they are only support.
Can they still have access to view the files and use Autodesk Viewer to do so?
Replies (12)
Message 2 of 13
Gabriel_Watson
"The Thin Client is compatible with Vault Professional only. There is no subscription or license requirement for Thin Client."
https://help.autodesk.com/view/VAULT/2022/ENU/?guid=GUID-B0A83CDC-490A-457D-8FE6-1744955E83AA
Therefore I think with Vault Basic you cannot grant access to those without Vault Basic installed. You can, however, share individual visualizations through Inventor Menu > Share > Share View, as those are shared on the cloud at https://viewer.autodesk.com
Message 3 of 13
ihayesjr
Vault Basic is an entitlement product. The people who are allowed to use Vault Basic are those who are licensed users of the following products.
  • 3DS Max
  • AutoCAD with Specialized Tools
  • Inventor Professional
  • Product Design & Manufacturing Collection
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 4 of 13
doug.johnston
Where I work, we have (3) CAD users and (4) non-CAD users using Vault Basic 2020. So it is possible.
The non-CAD have access to Vault Basic and are using Inventor Read-Only to view the models, drawings, etc.
You can setup different people with certain access rights so they can only view files and not check them out.
It's not easy maintaining this level of insanity !!!!!
Message 5 of 13
ihayesjr
@doug.johnston
Your non-CAD users using Vault Basic are going against the EULA. They should not be using Vault Basic as they do not have a license to any of the products I previously mentioned.
Vault Basic is not a free product.
Irvin Hayes Jr
Autodesk, Inc.
Message 6 of 13
rcolon9E4ZX
@ihayesjr ,
Is it possible to have the Vault Add-In loaded in Inventor Read-Only Mode 2022? This could be a good solution for our ACAD only users to view 3D models.
Rafael
Message 7 of 13
ihayesjr
@rcolon9E4ZX
No, that is not possible.
Irvin Hayes Jr
Autodesk, Inc.
Message 8 of 13
rcolon9E4ZX
@ihayesjr ,
OK. Thank you for the info, and the quick response.
Message 9 of 13
t.glowienka
And if I have users with flex tokens , can they use Inventor Read-only and Vault Basic? I assume they do not have full version of Inventor installed nor other Autodesk products. Just Inventor Read-only + Vault Basic Client via Flex tokens. Would that be against the EULA?
Message 10 of 13
DarrenP
What was said above the vault add in doesn’t work with Inventor Read Only
Yes this would be against the Eula like what was stated above
DarrenP
Message 11 of 13
t.glowienka
I want to open files from Vault Client without using full Inventor. i dont need Add-in for Inventor Read-only
Message 12 of 13
DarrenP
You can’t install the basic client without a qualiyifing cad application
Inventor read only is not one of them
You would need to install full inventor
This scenario was explained above
DarrenP
Message 13 of 13
ihayesjr
Vault Basic is an entitlement to users of the CAD products, like Inventor and AutoCAD.
If the user is not a full user of the CAD product, they are not entitled to use Vault Basic.
Irvin Hayes Jr
Autodesk, Inc.
