Seems I was confused by this new function in Vault. That it does use the Job Processor to run these files. So Maybe need to learn about the Job Processor then?
Seems to me that there should be a better way to create our pdf files then how we are currently doing it.
This is our current process that we are doing to update the pdf files for release process after engineering approval below.
1. With current new rev of Inventor open do a FILE - EXPORT - PDF and save that to your local drive.
2. Find pdf in vault and change state to WIP which will bump pdf rev to same revision as current new rev of Inventor
3. Will then double click pdf in Vault to open it and check it out of the Vault
4. Close the pdf view of the that pdf leaving the pdf Checked out in the Vault
5. Find that Checked out pdf in your current local work space and delete it
6. Copy paste in new rev pdf you created in step 1 into your current local work space replacing the one you deleted
7. Go to Vault find that this checked out pdf file and Check it into Vault
8. Verify that Vault is now showing the new pdf rev of the drawing
9. In Vault edit properties of the pdf to match the Inventor file properties (ECN might have changed some properties)
10. Change state of pdf file to be Released
This process works with no issues but it is time consuming. Currently working a ECN which will change over 100 drawings. So will have to do this process on everyone one of them.
Just looking for a better process for doing this.
