Visualization options, Enable Print
I must be loosing my mind... I have tried several time to set the "Enable Print" option to actually work like the help indicates it should, and it is just not behaving, again what am I missing here... What I'm looking for is to NOT print the  DWF visualization file...
I have set the 2014 and the 2016 rules:
The user is NOT an administrator, just a Doc Editor (1) and Doc Manager (1)
Two different user were tested both with same rights and rules, both still able to print visualization from from DWF viewer (Design review 2013), and from  a the viewer in the Vault preview window, I just cannot stop the basic user from printing the DWF (visualization) file...
So in short what the heck is "Enable Print" actually do?
MB
An Update;
Well Murphy is playing with me. I appears that it is now working, I changed the output location in the "Flat list" from the old location to different new location, and it started working? Don't know why, not sure how that steps on the process...
Anyway stand down, I'm not loosing my mind <grin>
MB
Senthil_Kumar
Not sure if that is the reason. But please note that the option "Enable Print" works only during the DWF creation. It will not work on the DWFs which were created before disabling this option.
Hope that helps.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Yes sir, you are absolutely correct,. What I could not figure out is why I had to re-establish the Flat folder location...
That is still a mystery to me... but it's working as should be at the moment...
MB
