Hello all!
We just encountered a problem with Vault and we cant find out what is going wrong.
Our library for the content center parts is default "....\Library\Inventor\Content Center Files\en-US"
As we cant switch to 2020 for some projects (the project doenst allow us to) we have to devide our library in a 2019 and 2020 version.
So we kept "....\Library\Inventor\Content Center Files\en-US" as our 2019 library and made "....\Library\Inventor\Content Center Files 2020\en-US" our new library for vault.
Our project file is based on default settings, so it uses the filepaths of the options per version.
Here we have set all the content center paths to 2020 folders for inventor 2020.
The weird thing is... when we check in a content center 2020 part like a bolt it wants to check in at a different folder "....\Library\Inventor\Content Center Files\en-US".... after checking in and opening the iProperties of the bolt it says it is in the "....\Library\Inventor\Content Center Files 2020\en-US" folder, and we can find it there too...
We cant figure out why Vault wants to check-in the file in another folder than its physically in...
Just found out that it also checks out at "....\Library\Inventor\Content Center Files\en-US" while the physically path of the bolt is "....\Library\Inventor\Content Center Files 2020\en-US"...
Does someone has a clue whats going wrong?
Kind regards,
Peter Ensing
