Vault rename using a numbering scheme should generate unique file names
AndriesMuylaert
AndriesMuylaert
Currently the Vault rename wizard generates duplicate file names when starting from a selection of duplicate files and using a numbering scheme. This results in an error 'This operation will result in one or more duplicate file names' when 'enforce unique file names' is enabled OR results in the same duplicate file names, both results are undesirable.
Why not simply generate truly unique file names when a numbering scheme is applied (especially in combination with 'enforce unique file names) ?
This would also allow to rename duplicate files in bulk...
ihayesjr
@AndriesMuylaert ,
I moved this from our Ideas board over to the forum.
The rename in this scenario should not work this way. Please log a product support case so that our development team can address it.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
AndriesMuylaert
Hi Irvin,
Thanks for the reply/suggestion.
I have created case ID 15618213.
Best regards.
Andries Muylaert
Elisabeth_Boehm
Autodesk Support
Autodesk Support
We are working under the Incident-Id: 24891
The status can you following under the link:
http://knowledge.autodesk.com/article/Vault-rename-using-a-numbering-scheme-should-generate-unique-f...
Elisabeth Böhm
Data Management
Senior Technical Support Specialist
Data Management
Customer Technical Success
Autodesk, Inc.
