Vault removes Xref layer overrides when renaming Xrefs
SunnyTurtle
SunnyTurtle
Hi Guys
I have come across an issue with renaming xref files
What I did
Rename xref files with the rename Wizard in Vault
Worked fine
This process works in the past
Then I go to get files that have the xref overlay or attached within them. And all the layer overrides have reset
At first i thought it was because VISRETAIN was set to 0 but it was set to 1.
Does anyone have any idea what cause the problem
Khin.Wathan.Aye
Hi rwcondon,
It was a known issue with renaming xref attachments, setting VISRETAIN to 1 won't help. The issue is fixed from Vault 2018 Update 2 onwards.
Khin
