Hi All,
I have an issue with the Vault. I sent the file to the Vault folder, the file properties are set in the Autocad:
like the example above,
but in Vault when I do "Edit Selected property" it removes all of them
To restore them I have to open the file (Check Out) and reapply the properties.
What could be the issue? It was working fine in 2021 versions...
I have Autocad 2023.1 Vault 2023.4 Build 28.4.20.0
Many thanks for the help.
Solved by jorgen.bjornes. Go to Solution.
Can you show us screenshot of the mapping settings for one of these properties?
So you have a two-way mapping on two autocad properties. I have also done this with lass than desired results...
Vault probably gets confused here..
I suggest you play with this, and only write to (vault->file) on ONE property.
Alternatively read (file->vault) for only one.
ordering of the properties may also be important.
Sorry for no definitive suggestion, but I am pretty sure this double mapping somehow is to blame.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Yes, that was the solution. However, it was a global Vault setting for the whole company and was not working only for me, so it seems the issue is more profound. But for now, it is working what I need to do
Thanks!!
