Vault purge "exclude versions where comment contains" -usage ?
Hello!
I am using Vault Professional 2019, build 24.1.42.0 (2019.1.1 Update), and i cant seem to get the "exclude versions where comment contains" - purge option to work.
So
So in the above picture i have made a test pdf to vault, which has 3 versions all in the workflow state "TYÖN ALLA", which is a "non-released" -state. As you can see i have commented the version 2 with the string "KEEP THIS VERSION" plus other comments after that.
Then like shown in the above picture i will do a file purge from Vault ADMS, and selecting the option "Exclude versions where comment contains", with the same string "KEEP THIS VERSION". Then the Vault will purge the files and i end up with this:
And as you can see from the above picture, the version that i wanted to keep, was indeed purged, any idea how i am supposed to be using the option "Exclude versions where comment contains" - in vault file purge?
Thanks!
