Announcements
Vault multi-site installation over cloud services
Claudio_Fortunato
Claudio_Fortunato
Hello!
I would like to know if it's possible to create a Vault multi-site installation in which one of the servers is a server installed in a Microsoft Azure or Amazon Web Service.
I know that this, in previous versions, was not possible, but I would like to know if now (version 2019) it is.
If this is possible, could someone give me some advice on how to set up such an environment?
Thank you very much in advance.
Claudio Fortunato
Consultor independiente
johannes.bauer
Autodesk Support
Autodesk Support
Ciao Claudio,
You might want to review this article
HTH
-Johannes
Customer Technical Success
Claudio_Fortunato
Hi @johannes.bauer
Thank you for your answer.
I had already read that article. With it, I learned several of the necessary settings to use Vault in the cloud.
That article mentions the restriction for servers synchronization in a mixed environment. But  it's from 2014. That's why I asked if in the new versions that restriction does not exist anymore.
I need to be able to determine it to offer one of my clients this mixed environment as a possible solution to their needs.
Claudio Fortunato
johannes.bauer
Autodesk Support
Autodesk Support
Hi @Claudio_Fortunato,
I think this was also available in previous versions.
Essentially you just need to ensure the connectivity between those servers using the dedicated Ports and DNS resolution. Depending on your connection to the Cloud provider (Private VPN or not) it would not differ from an implementation to an DMZ (see here)
But to make sure, I suggest to open a support case for this.
Johannes
HTH
-Johannes
Claudio_Fortunato
Thanks @johannes.bauer for your answers.
I'm going to do some tests with what you told me.
Best regards,
Claudio Fortunato
gerrardhickson
Hi guys,
Just following up on this. Has this been implemented successfully? Can you provide some details if so?
Regards
SonicFlow
Note similar post with some helpful details from users who had some success.
https://forums.autodesk.com/t5/vault-forum/using-vault-with-amazon-aws-cloud-service/m-p/5102916#M53...
