Vault mobile on ipad - PDF checkin
Tony_Yates
Message 1 of 18
Tony_Yates
Hi Guys,
I have just setup vault mobile on an ipad. I also have a lifecycle setup to change the approved PDF to a Markup state that creates a new version. In the mobile app I can change the state and check it out, add markups but cannot check it back in. It works well on a PC because the PDF is downloaded to the vault workspace and I can check it back in. ON the ipad I don't have checkin, I therefore try to add it back into vault but get an error 1008 a file with the same name already exists. Enforce unique file name is unticked. If I saveas with a different filename it will add it to vault or if I save it into a different folder.
Any ideas on how to force it to overwrite the checked out version?
or is my workflow incorrect ?
what workflow do you use for marking up PDF's with vault mobile?
Tony
Replies (17)
Message 2 of 18
gandhey
Hi @Tony_Yates ,
After checkout and adding a markup in the pdf file - you have the iOS 'Share' icon - 'Vault' is one of the option in the option list for 'Share'.
This is the option to check in the 'Checkedout and modified Pdf file' to Vault.
Yogeshwar
(Vault team)
Message 3 of 18
Tony_Yates
Hi Yogeshwar,
Yes that is what I was using to try and check back in, but it gives me the error 1008 a file with the same name already exists.
Tony
Message 4 of 18
gandhey
Hi @Tony_Yates ,
Please see my video below - are you using same workflow to check in back ?
If you dont use this checkin way but if you use Add files - then yes it might fail for duplicate file name as you are trying to upload in same folder - a file with same name.
(view in My Videos)
Yogeshwar
(Vault team)
Message 5 of 18
Tony_Yates
Hi Yogeshwar,
I am using an ipad and do not get the checkin text I just get add.
I noticed on your video it changed from add to checkin
regards,
Tony
Message 6 of 18
Tony_Yates
IPAD OS VERSION 17.5.1
VAULT PRO 2024
VAULT MOBILE 1.12.0
Message 7 of 18
Tony_Yates
Hi Yogeshwar,
I tried on an iphone and it has the same behaviour as the ipad.
Tony
Message 8 of 18
rosie_lucas1
Hi @Tony_Yates,
I wanted to check in and see if you still needed assistance or if you found a solution to your question already, please share the details so that other community users can benefit from the information.
Or, did the information provided by @gandhey help you and answer your question? If yes, please click on the "Accept Solution" button on the post that helped solve your issue. If not, please share any available screenshots or screen recordings so the community can assist you further.
Rosie | Community Manager
Message 9 of 18
Tony_Yates
Hi Rosie,
I still cannot get the checkin feature to work.
regards,
Tony
Message 10 of 18
gandhey
Hi @Tony_Yates ,
I did try the same workflow with a Vault 2024 update server - but I can checkin the file as expected.
Do you see this issue on all devices (if you have any other device - please the same workflow) and also may be uninstall app + reinstall to see if that helps ?
Yogeshwar
(Vault team)
Message 11 of 18
Tony_Yates
Hi Yogeshwar,
I have tried it on 2 different iphones and an ipad all are dong the same thing, no checkin available.
Tony
Message 12 of 18
gandhey
Hi @Tony_Yates ,
Only last thing I can suggest is trying the uninstall and reinstall of the app - if you haven't tried this.
Otherwise - please raise a case with product support as we will need some other means of investigation.
Yogeshwar
(Vault team)
Message 13 of 18
Tony_Yates
Hi Yogeshwar,
I have just tried uninstalling and reinstalled the app but still the same behavior.
Is it possible that its a setting somewhere?
regards,
Tony
Message 14 of 18
gandhey
Hi @Tony_Yates ,
Sorry to hear that hasn't helped either.
No there is no setting to control this.
Yogeshwar
(Vault team)
Message 15 of 18
BDCollett
I am assuming to 'CHECK IN' you will need to be logged in with an Autodesk Account that has either a Vault Pro or Vault Office license.
A view only login would only be able to view files.
This seems obvious to me, but I could be wrong.
Message 16 of 18
Tony_Yates
I am logged in with an autodesk account that has a vault pro license and not set to read only.
Message 17 of 18
BDCollett
Ok, disregard my post in that case.
Message 18 of 18
gandhey
Hi @Tony_Yates ,
We could get to the root cause of this issue. The issue is seen only when you are using a AutodeskID user account which is added as a user in Vault server.
As a workaround - please try using an AutodeskID account which is NOT added as a user in Vault for signin and use a Vault account to login to Vault.
We will look into this issue for addressing the same.
Yogeshwar
(Vault team)
