I am attempting to use windows authentication to log into a "Vault File Server" replicated to a full ADMS 2024.0.1 server on another space (Azure). All attempts to log in using Windows Authentication to the Azure server directly succeeded. Attempts to access the local server (File server - tied into the Azure server), have failed. The error is:
"Windows Authentication failed with the data management server..." For the ADMS on Azure, all IIS Windows Authentication nodes are enabled. The thin client allows windows authentication. Just when I change the server to the local server, it fails. The local server logs in fine using Vault Authentication.
Any Ideas for what's going on here?
Thank you,
Jamie V Johnson
