Vault Feedback/Beta program - How can I get access?
Serena.Lou
Autodesk Autodesk
Serena.Lou
As a participant in Vault Alpha/Beta program you can review pre-release functionality and provide your feedback directly to the Vault team. The feedback that you provide as part of the program is very valuable to the team and can have a direct impact on future releases of Vault.
How can I get access to Vault Alpha/Beta Program?
You can apply for access through the link http://bit.ly/AutodeskVaultBetaProgram
Firstly you need to have a Feedback account. If you don't already have one then you can create one from:
https://feedback.autodesk.com
Use your existing Autodesk login credentials or create a new account.
Or, once you have logged on to the Autodesk Feedback site, under the Open Opportunities section you will see a link called Vault. Click on that to apply for access, you will need to complete a quick survey to help us understand your Vault usage/history/background before you are granted access.
More general info about Autodesk Feedback program is available from:
https://feedback.autodesk.com/overview/
https://feedback.autodesk.com/faq/
Vault team keep updating the Feedback program with the new testing build and majority of new functionality is covered with test guides and videos.
You can leave us your comments directly from the Surveys/ discussion Forums and members from Vault team regularly monitor the problem reports to explain/clarify/quantify as required.
Beside Vault installer to download, we have also provide a way to enable Alpha/Beta testing for pre-release versions of Vault, without causing any impact to your current production environment. By using a technology called Frame - this enables you to try our most recent Alpha build of Vault directly in your browser. We host in 4 different geographical locations to ensure a good experience. It's pre-configured with sample data so all you do is click on a link & start using it in seconds. You can also upload your own data to test with & then when your session finishes everything "vaporizes".
We appreciate your participation and feedback, it enables us to produce better product, with higher quality.
Serena Lou
Serena.Lou
Vault 2020.2 Beta and Vault 2020 Addin Beta for Microstation are available now.
Serena Lou
Serena.Lou
Vault 2021 Alpha is live now!
Serena Lou
Serena.Lou
Hi all, Vault 2021 Beta in live now!
Serena Lou
