Announcements
Vault - element cards - change of format properties
tomasz_wejkowski
tomasz_wejkowski
(Vault) In the element cards there is no possibility to change format of the properties under admin rights - for example from text to number. Why there is no permission for this change if any property is set and confirmed?
ihayesjr
@tomasz_wejkowski
Thank you for posting the idea. Can you tell me what you are referring to when you say "element card?"
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
tomasz_wejkowski
@ihayesjr
Thank you for reply. I refer to Item Master.
ihayesjr
You need to change the property type in the Property dialog in the Vault Settings.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
tomasz_wejkowski
@ihayesjr
Currently when I set the new property I can choose type for example Text or Number. In any way when I try to change type cell for example from text to number in the state that property was set it is impossible. The cell is gray and it's blocked. What is the reason of such a situation?
ihayesjr
Can you provide an image of what you are experiencing?
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
tomasz_wejkowski
It's in polish language. Below it is shown when format of any property is set during creating.
Below You can find situation when format of property is saved and I can't change it:
