Vault database is not open.
Hi, Just looking for some explanations for the following message.
"The vault database is not open. Open database and compare component for editing." (Screenshot attached)
I get this message when I open an Inventor program through opening a file with Vault. I don't seem to be getting any errors or problems of any kind but I was wondering if anyone knows what Vault and Inventor is actually doing here.
Thanks!
johannes.bauer
Autodesk Support
Autodesk Support
It means, that your Inventor Addin is not logged into Vault and all changes you make cannot be checked back into Vault unless you login first - via Inventor.
HTH
-Johannes
Customer Technical Success
Jason.Courtemanche
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the Vault forum!
I'm just checking in to see if you need more help with this. Did the suggestion that @johannes.bauer provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Jason
