Vault Basic Copy Design File Status Column
RJR89
RJR89
In the 'File Status' column, can reuse be changed to copy for every item in a batch? or do I really have to go through every row for each item and change reuse to copy??
Rob
JamesMcMullen
Hi Rob,
If you are looking at Copying the entire assembly, you may want to do a "control" + "Left Mouse Button" Click on the parent assembly.  That will set everything to Copy.  Unfortunately, I am not aware of a way to do multi-select within the Vault Basic Copy Design.
James McMullen
Principal SQA Eng.
