Vault Basic 2025 - can't check-in new file after file rename in vault
JBerns
Advisor Advisor
Message 1 of 13
JBerns
Community,
I had a part in Vault named WH3855. It was used in two assemblies and drawings.
I renamed the file using Vault. New name is OBS_WH3855.
I created a new WH3855_17-4 part in my workspace.
When I attempt to check-in the new part, Vault reports the local part is out of date and needs to be refreshed. Check-In is not allowed.
Vault Basic 2025 Issue - Local copy is out of date - 2026-02-26_1016.png     2026-02-26_10-50-30.png
I have restarted Inventor, Vault, and my PC - Vault still thinks the local copy requires refreshing.
I checked-out the drawings and assemblies. I replaced the obsolete part with the new part. Vault still does not allow check-in. Insists old part requires refresh.
Other new parts can be checked-in, so I it does not appear to be a folder mapping issue or permission issue.
How can I get this new part in to Vault?
Thank you for your time and attention. I look forward to your feedback.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor Certified Professional
Autodesk AutoCAD Certified Professional
Replies (12)
Message 2 of 13
ihayesjr
In the Vault Browser, right-click on that part and select Go to Vault Folder.
Where does it take you in Vault?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 13
JBerns
It took me to the folder where the renamed (OBS_WH3855) file resides.
CAD Administrator
Message 4 of 13
ihayesjr
Have you tried logging out of Vault in Inventor and logging back in?
Irvin Hayes Jr
Autodesk, Inc.
Message 5 of 13
JBerns
Log out and reboots.
CAD Administrator
Message 6 of 13
ihayesjr
In Windows Explorer, did you just rename the original file to WH3855_17-4.ipt?
Irvin Hayes Jr
Autodesk, Inc.
Message 7 of 13
JBerns
No, renamed in Vault from WH3855 to OBS_WH3855.
Get renamed file from Vault into workspace.
Opened, modified and then Saved As the new name, WH3855_17-4.
Deleted local copy of OBS_WH3855.
Opened new file and tried to check-in. Reports out of date and needs to be refreshed.
I may try a few more attempts tomorrow, but if unsuccessful, I will delete renamed and its "where used" references.
CAD Administrator
Message 8 of 13
ihayesjr
Try saving it again as a different name and see if that one can be checked in.
Irvin Hayes Jr
Autodesk, Inc.
Message 9 of 13
JBerns
Irvin,
It failed to check-in.
I am going to just delete the file and its references and start over.
Thanks for the suggestions to resolve this issue. Much appreciated.
Jerry
CAD Administrator
Message 10 of 13
Doug_Spivey
Community Visitor
Community Visitor
Show hidden files, .dwf may be checked out and locked under old name.
Message 11 of 13
JBerns
I recall showing normally hidden files in the Vault and removing visualization (DWF) files too.
Still could not check it in.
As stated above, I deleted the problem files and checked in the new files.
Thanks though for the suggestion.
CAD Administrator
Message 12 of 13
River.EngumYTTWH
I'm having this problem as well. Pretty frustrating that this is happening with no apparent cause or solution.
Message 13 of 13
River.EngumYTTWH
I got around this by "Save As"-ing the 'new' file as a different file name. It may also help to force the .dwf (visualization) to update of the old version in vault to get the .dwf renamed. I haven't been able to test that yet though.
