# -*- coding: utf-8 -*-
import xlwings as xw
import zeep
@xw.sub
def main():
client = zeep.Client(wsdl=url)
sign_in = client.service.SignIn(userName='######', userPassword='######', knowledgeVault='######')
token = sign_in.Authorization
user_id = sign_in.User.Id
wb = xw.Book.caller()
numbers = wb.sheets[0].range('C2').expand('down')
i = 1 # Indice para recorrer columnas, uno menos que el range de numbers
# Acceso al servicio de Artículos
settings = zeep.Settings(extra_http_headers={'Authorization': token})
client_item = zeep.Client(wsdl=url_item, settings=settings)
# Acceso al servicio de Propiedades
client_prop = zeep.Client(wsdl=url_prop, settings=settings)
for rec in numbers:
i = i + 1
GetVaultItems = client_item.service.FindItemRevisionsBySearchConditions(
searchConditions={'SrchCond': {'PropDefId': 31,
'SrchOper': 3,
'PropTyp': 'SingleProperty',
'SrchRule': 'Must',
'SrchTxt': rec.formula,
bRequestLatestOnly=True,
if GetVaultItems.searchstatus.TotalHits == 1:
Title = GetVaultItems.FindItemRevisionsBySearchConditionsResult.Item[0].Title
Id = GetVaultItems.FindItemRevisionsBySearchConditionsResult.Item[0].Id
GetVaultItemsCustomProperties = client_prop.service.GetProperties(
entityClassId='ITEM',
entityIds={'long': Id},
propertyDefIds={'long': [37, 141, 165, 171, 172]},
Units = GetVaultItemsCustomProperties[0].Val
SapMatGr = GetVaultItemsCustomProperties[1].Val
SapMatTy = GetVaultItemsCustomProperties[2].Val
Aprov = GetVaultItemsCustomProperties[3].Val
AprovEsp = GetVaultItemsCustomProperties[4].Val
else:
Title = '####'
SapMatGr = '####'
SapMatTy = '####'
Aprov = '####'
AprovEsp = '####'
Units = '####'
if not wb.sheets[0].range('D' + str(i)).value:
wb.sheets[0].range('D' + str(i)).value = Title
if not wb.sheets[0].range('E' + str(i)).value:
wb.sheets[0].range('E' + str(i)).value = SapMatGr
if not wb.sheets[0].range('F' + str(i)).value:
wb.sheets[0].range('F' + str(i)).value = SapMatTy
if not wb.sheets[0].range('G' + str(i)).value:
wb.sheets[0].range('G' + str(i)).value = Aprov
if not wb.sheets[0].range('H' + str(i)).value:
wb.sheets[0].range('H' + str(i)).value = AprovEsp
if not wb.sheets[0].range('I' + str(i)).value:
wb.sheets[0].range('I' + str(i)).value = Units
if __name__ == "__main__":
xw.books.active.set_mock_caller()
main()
