Vault 2023 Copy Design Not working Correctly
m.den.ouden
m.den.ouden
After a Copy design action in vault 2023 the Part Number is not updating anymore.
It always worked before in Vault 2022 and versions before that. This is a big problem cause all the references are incorrect. Can this be fixed as soon as possible?
Gabriel_Watson
Are you using the default rule for copy design, or some other? If another, you might have to add this bit:
