Vault 2022 User Display Name
ThomasRambach
Advisor Advisor
Message 1 of 28
ThomasRambach
In Vault 2021, our Vault usernames "User Name" are like {DOMAIN}/{USERNAME}
In Vault 2022, it removes the "User Name" field and replaces it with "Display Name" like {Lastname}, {Firstname}.
Generally, I like the options in Vault 2022 but is there a way to retain the "User Name" information like it had in Vault 2021? We have a lot of other systems that need to be updated that require this field as-is.
Replies (27)
Message 21 of 28
ihayesjr
@ThomasRambach
Good point. However, why email addresses and not the user's full name?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 22 of 28
ThomasRambach
@ihayesjr We have a big enough organization that some names are duplicate based on how AD has them set. You really need to look at the email address sometimes for more common names.
Message 23 of 28
ihayesjr
@ThomasRambach
Why not a combination of both the display name and email address?
For example:
Thomas Ramback (email address)
Or
Thomas Ramback (AD login)
Irvin Hayes Jr
Autodesk, Inc.
Message 24 of 28
ThomasRambach
@ihayesjr That does work. Except the column width takes up a lot of screen real estate.
Message 25 of 28
michael_marx
Hi Irvin,
if you point out to the API.
I can´t find a class member for the display name inside the user class.
Do you have a link or code example?
regards
Michael
Message 26 of 28
ihayesjr
@michael_marx
What are you trying to accomplish through the API?
Irvin Hayes Jr
Autodesk, Inc.
Message 27 of 28
michael_marx
Hi Irvin,
i´ve got a code that reads the username when change the lifecycle.
With the old Vault Account login i get the old username of the logged in user.
with the new Autodesk Account login i only get the email of the Autodesk Account login.
So i´ve to adress this behaviour with changing my code to read the display name.
Michael
Message 28 of 28
Zhang_ChengARS2Q
I would like to know how to use the parameter Vault_username as a filter in the customized report before, and now how to use the Display Name as a filter
