I set up a new Vault 2016 server & client on same machine at home.’The problem I have is any time I check out files to work on them the status icons always turn red and message is “file has been moved or renamed” (I have done neither)
Then sometimes when I try to refresh files it gets checked out to someone else
(but I am the only user)
Also, Vault duplicates the folder structure in the workspace, creating another set of
folders & files directly under the root (not proper location). Even after checking all in,
delete all files & folders in work space, after another check out this happens again.
And one more thing, normally with our vault at work, if I create a folder in the vault,
then right click on it, then select “Go to Working Folder” Vault will create this folder
in my workspace. This does not happen at home. no folder is created like that.
I suspect it is mapping, or project issue somehow, however I have tried just about
everything (I know of) to resolve it without success, even copying all our settings here.
What is going on? And How can I fix it?
Thanks, Don
