Solved by administrator. Go to Solution.
Here is the install log
2012/10/18:04:29:48 administrator ENGINEERING === Setup started on ENGINEERING by administrator === 2012/10/18:04:29:48 administrator ENGINEERING Launch 2012/10/18:04:30:25 administrator ENGINEERING === Setup ended ===
2012/10/18:04:29:56 administrator ENGINEERING === Setup started on ENGINEERING by administrator === 2012/10/18:04:29:56 administrator ENGINEERING Launch 2012/10/18:04:30:25 administrator ENGINEERING PageOpen InstallDotNetDialog 2012/10/18:04:34:10 administrator ENGINEERING PageOpen LaunchDialog 2012/10/18:04:34:16 administrator ENGINEERING PageOpen LicenseDialog 2012/10/18:04:34:19 administrator ENGINEERING PageOpen ProductSelectionDialog2 2012/10/18:04:34:23 administrator ENGINEERING PageOpen LicenseDialog 2012/10/18:04:34:24 administrator ENGINEERING PageOpen LaunchDialog 2012/10/18:04:34:26 administrator ENGINEERING PageOpen LicenseDialog 2012/10/18:04:34:29 administrator ENGINEERING PageOpen ProductInfoDialog 2012/10/18:04:35:55 administrator ENGINEERING PageOpen ProductSelectionDialog2 2012/10/18:04:36:08 administrator ENGINEERING PageOpen FullProgressDialog 2012/10/18:04:36:09 administrator ENGINEERING Installing ADMS System Check: E:\x86\en-us\edmprechecks\edmwrapper_win32.exe /qw /prechecks /c "COMMAND_GROUP=Precheck SQLPASSWORD="AutodeskVault@26200" DATADIR="" IISPORTNUMBER="80" IISWEBSITENAME="Default Web Site" ISUPGRADE="FALSE" UILANGFOLDER="C:\Users\ADMINI~1.ESS\AppData\Local\Temp\1\_AIC098.tmp\en-us"" 2012/10/18:04:36:54 administrator ENGINEERING Install ADMS System Check Succeeded 2012/10/18:04:36:54 administrator ENGINEERING Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q /norestart 2012/10/18:04:50:53 administrator ENGINEERING Install .NET Framework Runtime 4.0 Succeeded 2012/10/18:04:50:53 administrator ENGINEERING Installing .NET Framework Runtime 4.0 KB2468871: E:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart 2012/10/18:04:59:42 administrator ENGINEERING Install .NET Framework Runtime 4.0 KB2468871 Succeeded 2012/10/18:04:59:42 administrator ENGINEERING Installing Microsoft WSE 3.0 Runtime: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ADMINI~1.ESS\AppData\Local\Temp\1\_AIC098.tmp\Media.mst"
2012/10/18:04:59:45 administrator ENGINEERING Install Microsoft WSE 3.0 Runtime Succeeded 2012/10/18:04:59:45 administrator ENGINEERING Installing Autodesk® Vault Collaboration 2013 (Server): TRANSFORMS="E:\x64\en-us\ADMSCollaboration\Col_Server.mst;C:\Users\ADMINI~1.ESS\AppData\Local\Temp\1\_AIC098.tmp\x64\ADMSCollaboration\Col_Server-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\ADMS Collaboration 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/18:05:02:45 administrator ENGINEERING Install Autodesk® Vault Collaboration 2013 (Server) Succeeded 2012/10/18:05:02:45 administrator ENGINEERING Installing Autodesk® Vault Collaboration 2013 (Server) Language Pack: TRANSFORMS="C:\Users\ADMINI~1.ESS\AppData\Local\Temp\1\_AIC098.tmp\_laEE42.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\ADMS Collaboration 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/18:05:09:12 administrator ENGINEERING Install Autodesk® Vault Collaboration 2013 (Server) Language Pack Failed Installation aborted, Result=1603 2012/10/18:05:11:30 administrator ENGINEERING Rollback Autodesk® Vault Collaboration 2013 (Server) Succeeded 2012/10/18:05:11:32 administrator ENGINEERING Rollback Microsoft WSE 3.0 Runtime Succeeded 2012/10/18:05:11:33 administrator ENGINEERING Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619 2012/10/18:05:11:33 administrator ENGINEERING Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
Hey there,
Can you look at the following solution: http://crackingthevault.typepad.com/crackingthevault/2010/10/error-29001-vault-management-error.html
All installed. Had to remove IIS and reinstall IIS and then the install workedl
