Value cannot be null. parameter name path 2
Message 1 of 13
I'm trying to do Copy Design in Vault Basic 2022 and I'm getting an error message: Value cannot be null. parameter name path 2. Anyone know of a fix?
Bill
Replies (12)
Message 2 of 13
CGBenner
@Anonymous
Can you check to make sure you're not missing a field that needs a value, such as new file name or destination path, or anything similar?
Chris Benner
Message 3 of 13
Here is what I have for my Vault Settings.
Message 4 of 13
CGBenner
@Anonymous I meant in the process of the Copy Design.... isn't that where you are seeing the error?
Chris Benner
Message 5 of 13
Correct, I browse to the folder in Vault. I right click the file to copy. I select copy design. And this when I get the error.
Message 6 of 13
I'm getting this error message before I get to the dialog box for copy design. It is when I right click on a file and click on Copy Design when the error message appears.
Message 7 of 13
CGBenner
@JamesMcMullen @Senthil_Kumar
Do you guys have any ideas on this error, this is not one I have seen before.
Chris Benner
Message 8 of 13
JamesMcMullen
I have not seen this error before either.  Is this happening with specific file types or with all files?  Also, are you on the latest version of 2022 or a different version?
James McMullen
Principal SQA Eng.
Message 9 of 13
billnurre
Observer
Observer
This error is happening on .iam files. It is not happening on all iam files. I'm on version 2022.1.1.
Message 10 of 13
tracyp
I have this issue too. Any fix yet?
Message 11 of 13
tracyp
Mine happened while trying to copy an inventor dwg file. Vault version 2022.2 Update
Message 12 of 13
Gabriel_Watson
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
If that official solution does not work, try this older one here:
Change the working folder to "C:\Vault\" instead of "C:\"
https://forums.autodesk.com/t5/vault-forum/vault-2012-copy-design-error-value-cannot-be-null-paramet...
This one is apparently good if you simply change the option in Vault administration to enforce working folder:
  1. Select Tools > Administration > Vault Settings.
  2. In the Vault Settings dialog box, click the Files tab.
  3. In the Working Folder section, click Define.
  4. In the Working Folder Options dialog box, specify whether clients can define a working folder or whether a consistent working folder location is enforced for all clients.
Message 13 of 13
ReinierP5648
Is there an offical solutsion? I tried the work around but still getting the error.
Vault 2024.3 Does apply to some, not all iam's
