Update about Inventor instance properties being overwritten in Vault Item BOM (Incident ID 43326)
Majjek
Majjek
Is there any update on the issue where Assign/Update Item overrides instance properties from Inventor (recorded as incident ID 43326 at Autodesk)?
When looking at the Vault API and retrieving the BOM object for a file with instance properties (which is just checked in from Inventor), you can find the instance property under the 'InstPropArray' property.
But after a synchronize property action, that property is set to nothing.
Making this functionality practically useless.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Assign-Update-item...
Kind regards
Edit: Working with Inventor/Vault 2025.4.
gandhey
Hello @Majjek ,
This seems resolved in Vault 2027 release.
Yogeshwar
(Vault team)
Majjek
Hi @gandhey ,
Thanks for your quick reply.
Will this be fixed in 2025?
Our update to 2027 is not scheduled until the end of this year.
lauri_barnhart
Hi @Majjek, thank you for your question.
Did the response provided by @gandhey help answer your question?
If yes, feel free to click on the Accept Solution button.
This helps other users benefit from the information.
In case you still need help, please provide an update here so we can help you best moving forward.
Lauri | Community Manager
Majjek
Hi @lauri_barnhart ,
I asked another question to which @gandhey didn't reply yet.
gandhey
Hi @Majjek ,
As there is no business case / escalation here. This will not be fixed in 2025 stream.
Yogeshwar
(Vault team)
Majjek
Ok that's too bad...
I do have a work around in place already, but it's not that pretty 🙈.
