Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Time out on Vault thin client
JasonMayes
JasonMayes
I would like to extend the time that the thin client can stay open. Our parts and service department likes to leave and instance of the client running as the day goes on to look up drawings throughout the day. Currently they may let it sit for 30 minute or longer before "needing" it and they are greeted with an error stating that it has timed out and must be restarted. They must close IE and reopen another instance. They have requested me to extend this time that the session stays active.
So...
Is it possible to do this and where do I change this?
Jason Mayes
Deister Machine Co.
Replies (14)
ihayesjr
See if checking the box to automatically log in helps. You cannot increase the timeout of the Thin Client without effect the thick client connections.
Irvin Hayes Jr
Sr. Product Manager
Vault - Under the Hood Blog
gilsdorf_e
our users are reporting the same issue. According to them, the checkbox does not help.
Regards
Erik
JasonMayes
When we used 2016 Vault the "keep me logged" box was checked and it didn't seem to cause any issues. When we upgraded to 2018 the "keep me logged in" being checked caused other issues that I cant recall but I know the only solution we found was to uncheck that box and make sure the browser was deleting its cache and cookies on exit. Another side effect was we could no longer use Chrome. In fact the browser we found to work was IE 11.
ihayesjr
On the server, you can try and increase the connection timeout by selecting the Default Web Site, click the Limits option on Connections in the right pane. The default timeout should be set to 900 seconds. See if increasing this value helps.
Irvin Hayes Jr
Sr. Product Manager
steveh3
Irvin...does this still apply to new Thin Client? Does it still affect Thick Client too if you extend them?
Best,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
steveh3
Found this too....
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Ours is set to 60, but it doesn't help. Seems to be stuck around  20 mins.
Steve Hilvers
ihayesjr
@steveh3
If IIS is still set at 900 seconds, it will timeout sooner.
I recommend trying to increase the IIS timeout and see what happens.
Irvin Hayes Jr
Sr. Product Manager
steveh3
So, I increased IIS to 1800 seconds....see what happens.
Also...going thru webconfig file I found this......
That have anything to do with it?
<!-- interval timeout to determine inactive sessions -->
<add key="SessionInactivityTimeoutInterval" value="0:30:0" />
Best,
Steve Hilvers
ihayesjr
Did you edit the connection timeout in the Advanced Settings?
Vault 2023 Help | Access Advanced Server Settings | Autodesk
Irvin Hayes Jr
Sr. Product Manager
steveh3
Thanks Irvin....
The IIS change did not make a difference.
I changed the ADMS Advanced Setting Time Out from 1000 (16 mins) to 3600 (60 minutes).
See what happens.
Thx
Steve Hilvers
steveh3
Irvin...
Changing Advanced Time Out to 3600.
Doesn't appear that that worked either.
 I did not restart SQL or anything like that.
Just made change on ADMS and closed console.
Thoughts?
Steve Hilvers
steveh3
@ihayesjr ...
Any other thoughts? Support Request for 2023.1?
Steve Hilvers
ihayesjr
@steveh3
Changing the above value should have done it. You can create a support case to see if there is something that is causing it not to work.
Irvin Hayes Jr
Sr. Product Manager
steveh3
Looks like I had a short circuit between my chair and keyboard.🤔
Somehow I created a syntax error in the web config. I brought back a copy of the original one I had edited and made the change again.
Now it works.
So, lesson to this discussion...before edit a config file, always make a backup 😁
Thanks for the help!
Steve Hilvers
