splitting the FILESTORE into Two separate/distinct Drives?
Message 1 of 13
is there anyway to split the FILESTORE into Two separate/distinct Drives? i mean can i damage the files or the app by doing this? is there any risk?
im having vault 2013 version.
Replies (12)
Message 2 of 13
paul.gunn
There is really not way to do this. If you have multiple vaults, it is possible for each vault's filestore to be on a different drive. However the filestore for a given vault is assumed to be on a given drive.
Paul
Message 3 of 13
can you provide me more information on how to do it??
thanks in advance
Regards!
Message 4 of 13
paul.gunn
In ADMS console, you simply select your vault in the main tree and run the 'move file store' command.
Hope this helps,
Paul
Message 5 of 13
you mean this is only a vault right and if i had more than the nuclear vault that would say that i have multiple vaults?
am i right?
Message 6 of 13
paul.gunn
Yes -
If you have multiple vaults then each can have their own filestore location (each on different drives). However for a given vault, the filestore only has one location.
Paul
Message 7 of 13
and there is no way i can split that vault? or something like that?
Message 8 of 13
paul.gunn
I'm sorry -
There is really no way to split a filestore for a single vault into multiple drive locations.
Paul
Message 9 of 13
Thanks a lot, another question and maybe the last one i have, is that is there anyway to put a autolock mechanism on the ADMS when you log in.
Regards!
Message 10 of 13
paul.gunn
Could you clarify what is meant by 'autolock'?
Paul
Message 11 of 13
yes we dont want to have unlimited times to log in we want to have an action to lock the account when they try more then 3 times
and paul back to the file store
what I wanted to find out is if there is a way to “move” data from One Vault to another Vault..
Basically the steps I was trying to find out if it was even possible were:
  1. Create a new Vault, call it Nuclear1 (or whatever we decide)
    1. Define the filestore on a different disk drive.
  2. Move a Folder (for example RXS) from the Nuclear vault to the Nuclear1 vault
Message 12 of 13
you know what paul, we already find a fix for the File Store sorry for been confusing, but on the autolock i do need help i presume that im gonna need a third party app to do this right?
Message 13 of 13
paul.gunn
You are right - there is no autolock functionality built into vault. Glad to hear you are set on the other issues.
Paul
