Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Set Copy Design property values as custom value or with suffix
4 REPLIES 4
ReneRepina
338 Views, 4 Replies
Greetings!
Is there an option to set Copy Design property values as some custom property or to add suffix to existing value?
We are using Vault 2020.3.7.
Best regards,
Rene Repina
4 REPLIES 4
ihayesjr
in reply to: ReneRepina
No, you cannot set custom property values during Copy Design.
You can vote on this idea.
Edit properties during a copy design - Autodesk Community
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
ReneRepina
in reply to: ihayesjr
Hi @ihayesjr !
Thanks for sharing the link, will do!
Gabriel_Watson
As a workaround I usually employ copy design rules that will wipe out a custom property clean (to blank), so the user can change that later on his own (using the property editor in Vault for multiple files at a time, most often).
ReneRepina
in reply to: Gabriel_Watson
@Gabriel_Watson
The thing is that I would like to implement suffix to specific fields, so users still have a reference to original copied file and new one has some information that it was copied from it (variant). I could make it "Blank", but then they will have to search in some other way to find out from which it was copied (complicate things for users). And if I leave it as it is, users forget, leave them as they are and we have duplicates. Suffix would solve it all. ^^
It would also be great to change user display name, because currently we have users in domain, their usernames are not grammatical and we would have to change them if we would use "user" property override.
