Select a single Column in List
RajSchmidt
Advisor Advisor
RajSchmidt
Hi Folks,
I sometimes need a quick&dirty list of Vault objects, e.g. a list of item numbers.
Right now, I do a search for the stuff. Then I select everything in the list (ctrl + a) and copy it. Now I switch to Excel and insert my copied data. In Excel I copy only the column I need or delete the ones I don’t.
I am wondering if there is a quicker way to do this. Can I select and copy only a single column in Vault?
Regards
gandhey
Currently this is not possible to select data for copy based on single column.
However workaround could be just have the intended column in the grid and copy over things you need to copy.
And reset the view or add required columns once copy is done.
Yogeshwar
(Vault team)
RajSchmidt
Hello @gandhey ,
thank you for the answer. I guess it’s time for another idea 😁
