Saved searches
Saved searches
johan.degreef
Advisor Advisor
Saved searches
johan.degreef
Were can I export my saved searches for later use)? The list is not long yet, but am trying to add tings. Don't like to have to rebuild it some day, so were can I find the file that holds these searches?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
gandhey
Hello @johan.degreef ,
Saved searches are stored in %appdata% location. Please refer below for details :
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/simplecontent/content/copyi...
Yogeshwar
(Vault team)
johan.degreef
Thank you. It would be great if that would be automated with export/import buttons!
CGBenner
@johan.degreef
It looks like you can export to a .xls file if you edit the Search and go to the File tab in the edit window.  I haven't tried it, but it might be worth a look.
Chris Benner
vali_dobrea
@CGBenner the export only extracts the search results with the same grid
