Parts, assemblies and drawings all have a revision property that you can map into a drawing title box.
My question is this: which of these should drive the revision number on the drawing?
- If you make a design change to the part or assembly, this triggers a revision. This is (or seems to be) obvious.
- If you correct a drawing error, or make an addition to a drawing, this also can/should trigger a revision change, even though the part itself has not physically changed. If your revision number is driven by the part, you would need to manually bump the part revision to change the drawing. This seems wrong.
Any thoughts?
Paul
