Released file property sync problem
Olgan
Olgan
Hi everyone,
Is there a way to manually order job processor to synchronize released file properties?
Sometimes job processor fails to sync the files and I can't manually do it because the files are locked.
When they are in error state in job queue I can re-submit but I can't see them in job queue all the time.
RajSchmidt
AFAIK out-of-the-box you could only log into Vault as Jobprocessor user and sync the files with these elevated rights. That should work if it happens only occasionally
If you need it more of the you will have to script a custom job.
