Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Project Explorer slider bar for properties grid with the Vault Client
2 REPLIES 2
kwilson_design
217 Views, 2 Replies
I would love if the dev team could bring the slider bar that already exists in advanced searches (the "Find" button) and in any custom saved search, over to the main Project Explorer property grid. When a user adds several properties to be visible in the grid, it forces the user to constantly micromanage expanding property column names so that you can see the entire property name. With a slider bar like used in other areas of the Vault Client, it allows the user to have however many properties columns they want visible with fully expanded column names while being able to easily slide or side-scroll to view all of the properties at a glance.
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
Labels (1)
2 REPLIES 2
ihayesjr
in reply to: kwilson_design
@kwilson_design
You should already have this capability. Right-click on any column and select Customize View. The in Other Settings disable the automatic column sizing.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
@ihayesjr man, I have never once gone into the "other settings"! Thanks a ton sir!
Kenny
