Problem Changing Lifecycle
Eli_Dexter
Eli_Dexter
When Changing Life Cycle for a document user gets Message: "You do not have adequate permissions to perform this operation". User belong to the group that has the following roles: "Document Editor (Level 1),Document Manager (Level 1)". User has Modify right to the folder. User also has modify right Lifecycle State in Lifecycle definition. What other roles/rights the user supposed to have to be able to change lifecycle.
cbenner
@Eli_Dexter
Does this happen on all files, or just in certain folders?  I would check the permissions on the folders themselves.  With permissions, the lowest level always wins.  So if they have permission on the life cycle state transitions, and have the correct roles, but the folder permissions are lower... that would become their effective permission.  Something to check anyway.
Eli_Dexter
The issue was that the user had only Document Manager (Level 1) role. I have given him Level 2 permission and it solved the issue.
Thanks to everybody who contributed to this subject.
