Object reference not set to an instance of an object
JMGunnar
Message 1 of 40
JMGunnar
Any more tips too this error
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
1.try too start workgroup 2020 after we change license
2.reinstall vault client
Best Reagards Johan
Accepted solutions (3)
Replies (39)
Message 2 of 40
JMGunnar
Here my solutions after many hours
reinstallation of Vault client
I rename ADPSDK mapp
%APPDATA%\Autodesk\ADPSDK
please update this info in
Message 3 of 40
tomkennedySKK7K
Observer
Observer
Thank you very much for posting this, saved me a lot of time.
Though I do wish I'd checked the forum before trying all steps on the Autodesk steps (including deleting the users profile!) 🙂
Message 4 of 40
Edoardo.Baima
thank you so much @JMGunnar .
Tagging @CGBenner to have the article updated since right now it isn't helpful without Gunnar tip. Thank you
“Raise your words, not voice. It is rain that grows flowers, not thunder.”
― Rumi
Message 5 of 40
steveh3
THANKS!!!! @JMGunnar
Anybody know what is causing this?
We are on ADMS 2023.2 server and were still using 2021 Thick Client. Last night we had 12 of our 48 of our users where we had to rename this folder. Some were Windows 10 others were Windows 11 machines.
Something happened and we had to rename the %APPDATA%\Autodesk\ADPSDK  folder?
Seems kind of ironic that others had same issue last night and this discussion was at top of list.
Autodesk any thoughts?
Best,
steveh
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Message 6 of 40
ArkanceBeluxSupport
Multiple customers in Belgium are facing same issue since this afternoon!
Renaming %APPDATA%\Autodesk\ADPSDK  folder solved issue.
Message 7 of 40
steveh3
We are up to about 24 out of 48 users. Some users were even logged in and were knocked off and can't get back in until we renamed the folder.
Best,
Steve H.
Steve Hilvers
Message 8 of 40
sellis
Thanks! Nice quick fix. 🙂
We just had two users run into this issue today. Both had inventor crash when interacting with vault.
Message 9 of 40
mslosar
At this point I can tell you we're up to like 6-7 people reporting this here this morning as well. Something clearly changed and for this many people, has to be the autodesk end of the spectrum.
Message 10 of 40
ihayesjr
All,
The files in the folder you are renaming is used by an Autodesk component called ADP.
A recent update to the component installed a version of the file that broke Vault 2021.
We are working on getting the component re-released with a fix.
I hope we can get this re-released ASAP.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 11 of 40
steveh3
THANKS for the update Irvin!!!
At least we know how to fix it and what caused it.
Appreciate it!
Best,
Steve H.
Steve Hilvers
Message 12 of 40
karthur1
I just had a user on 2020 have this same issue.  I followed the KB article but problem still persisted, then I found this post.  Renaming the ADPSDK folder did the trick.  Note: It would be nice if they would update the KB webpage.
Message 13 of 40
ihayesjr
The article has been updated. You may have to clear your browser cache to see the update.
Irvin Hayes Jr
Autodesk, Inc.
Message 14 of 40
elin.bosma
Observer
Observer
Renaming the folder works. But with me, it only works for an hour or so darafter I have to repeat the process.
Message 15 of 40
Richard.Rankin
Autodesk Support
Autodesk Support
Hi All,
Autodesk has released an update to address this issue.
It will automatically self-update all machines connected to the internet within the next 24 hours including the impacted users and the workaround will no longer be required.
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
Autodesk, Inc.
Message 16 of 40
steveh3
Thanks Richard and your team for the update.
FYI...We already had a couple of machines this morning, where we had to use the work around a second time. If it still persists on Friday....I'm sure somebody will let you know :-).
Best,
Steve H.
Steve Hilvers
Message 17 of 40
L00K
Hi Richard,
question: how or where can we access mentioned update?
We are behind the firewall so non of the updates will show up automatically in out systems,
Does this updated apply to client or server?
Best Regards
Lukas
Message 18 of 40
Richard.Rankin
Autodesk Support
Autodesk Support
Hi Lukas,
Are any of your users impacted??
Richard Rankin
Autodesk, Inc.
Message 19 of 40
L00K
yes, 5 so far.
Message 20 of 40
lscadden
Has anyone that solved this by following the process listed and wound up with a different complication opening files from Vault?  The work around did work however, now I am getting this message opening from Vault:
Even after deleting my working folder copy of the project file and performing a "get" from Vault to replace it I am still dealing with this issue ...   I am just curious as to if this is a related issue most of us are seeing or if coincidentally this is an unrelated issue that happened to do this after the workaround.  I even tried a reinstall Vault to fix this one.
It did not work!
Luke Scadden
Nuaire Inc.
WIN 10
Inventor/Vault 2020
