need correct Vault update 2018.3.3
I need to connect to my customers Vault and they say that my Vault build# and update# need to match theirs even though we are both running Vault Basic 2018. My build# matches but my update# is 2018.3 theirs is 2018.3.3. I was able to find Autodesk_Vault_DataStandard_2018_3_3_ but after running the setup file there didn’t seem to be a change in my Vault update#. Two questions 1) do both build# and update# need to match for me to check in/out files from their vault, and 2) how can I get update 2018.3.3?
ihayesjr
  1. Vault Data Standards doesn't work with Vault Basic.
  2. You don't need to be on the same update as the server to connect and check-in and out.
  3. You build matches so you will be fine. We have had instances where the Update # doesn't get reset correctly which could be the cause of the problem.
  4. You could have everyone install Vault 2018.3.8 Update and you will definitely match.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
thank you
