Is there no way for Shaded with Edges to be enabled by default in ADR?
shlee3983
shlee3983
Hi~
I'd rather prefer to see shaded with edges by default Set while opening in Autodesk Design Review.
cbenner
@shlee3983
I honestly do not see a setting for that.  That might be something for the Vault Idea Forum.  It would be nice to have that choice.  Post your idea and then post a link to it and ask for votes.  I'll vote for it.
Jason.Courtemanche
Hi @shlee3983,
I'm just checking in to see if you need more help with this. Did the suggestion that @cbenner provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Jason
Jason.Courtemanche
Hi @shlee3983,
@cbenner is correct Autodesk Design Review does not have an option to change the default setting from Shaded to Shaded with Edges.
This also happens if you launch Design Review and then open a dwf file. Then make the change to share with edges, close and reopen the same dwf the setting is back to shaded. Design Review does not have an option to change this setting and make it the default. The next step would be to request this enhancement be added to the product.
Jason
