is there a way to change the Thumbnail view. So that it show that I see as importent to see ?
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 9
I would like to make the Thumbnail to better show what I need to see. I would like to control what the Thumbnail is showing.  maybe just show an zoom in of that have been change form this version form the previous version. So If I what to copy an old design ... It would be easy to find the right one ... without having to open them all to find it .
Can I control what the user is seeing in vault Thumbnail ?
Replies (8)
Message 2 of 9
ihayesjr
The thumbnail is extracted from the file when the file is checked into Vault. CAD products do not have a way to force a specific thumbnail to be saved in the file.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 9
what I was looking for what a way to control which view was extracted from the file when the file is checked into Vault.
I do not want to add an my our ... only control what standard view that inventor does take the picture form. it that possible
Message 4 of 9
ihayesjr
My point is this, the Thumbnail is a property in the file that has an image. For you to control the view, you need to be able to control the view saved in the file Thumbnail property. There is no way to control the view saved in the files Thumbnail property in the CAD product for Vault to extract and display.
Irvin Hayes Jr
Autodesk, Inc.
Message 5 of 9
That too bad . it could use right save a lot of time
Message 6 of 9
CGBenner
@Darkforce_the_ilogic_guy
Maybe a suggestion would be to add comments in Vault to the files, so that you can look at those to determine if they are the correct files before you copy design.
Chris Benner
Message 7 of 9
cstarker6VCG4
Doesn't the View Cube determine how the thumbnail image is oriented?
Message 8 of 9
ihayesjr
@cstarker6VCG4
The Thumbnail view is set by the iProperties of the file.
Irvin Hayes Jr
Autodesk, Inc.
Message 9 of 9
cstarker6VCG4
I just tested it and Active Component ISO View on Save is determined by the View Cube. Default orientation is:
