Just wondering if anyone else has tried to change the order of the custom views in the drop down list. The new view that I make is always at the bottom of the list. Would like to change the order or sort them at least...
Solved by stevenpayne89. Go to Solution.
Solved by cbenner. Go to Solution.
@stevenpayne89 From what I can see these are listed in the order that they are created, with the Out of the Box options listed at the top. I am not aware of any way to change this.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I've started an Idea post for this:
