Inventor Vault Add in fails to log in 2024
I have Vault 2025 Sever (local host), and Vault 2023, 2024, and 2025 clients installed. they all work fine both from the Vault client interface and the Inventor respective version Add-in except for IV2024. when it tries to log in to Vault the message below appears, if you hit OK and try to log in again, once you select the Vault from the list, the Unhandled exception error message pops up. I have tried to clear uninstall, reboot, and reinstall the 2024 client and it did not fix it. I also have repaired the C++ Redist versions just in case they are corrupt and that did not fix the issue either. Before this, I had 2022,2023, and 2024 clients running side by side, with no issues. could this be related to Net Framework 8 for the 2025 version that conflicts?
any help with this would be greatly appreciated
Best
Ali
