Announcements
Inventor 2022 Check in library parts fails
nico.de-neef
nico.de-neef
When I open library part in Inventor 2022 and try to check in to vault nothing happens.
If I place that librarypart in an assembly en check in assy, the library part is checked in...
Is this normal behavior?
bradeneuropeArthur
What do you mean with library part:
  1. Content Center Part
    1. Vault Content Center
    2. Destop Content Center
  2. Libraries create by your company that are used as standard and as library Parts
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
nico.de-neef
I can reproduce this with every library part (content center files and our own libraries).
In the screencast I demonstrated with my own created (test) librarypart.
https://autode.sk/3B4lrpU
We can reproduce this on multiple 2022 environments (server and client).
bradeneuropeArthur
What if you disable the numbergenerator!
Arthur Knoors
ihayesjr
This is not normal behavior.
Can you share an image of the Project's mapped Vault Folders?
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
