installing vault basic server 2017 windows pro 10 64 bits
HeptaProyectos
HeptaProyectos
(sorry for my english)
hi, i have several issues when i install autodesk vault basic server 2017 with windows 10 pro 64 bits regional settings spanish mexico or latin america.
first, i want to complain with autodesk, is unbelievable, i download vault basic server 2017 spanish language installer (VBS2017_ESP_64bit_dlm.sfx), 1.7 gigabytes, and i need to change regional settings from spanish mexico to spanish spain!! is insane!!!!! AUTODESK i am downloading SPANISH!!! version, right now i solved that, then installer try to install sql express 2012 version but the installer doesn´t have folder x64 only x86, more insane!!!, i am downloading vault installer 64 bits!!! no 32 bits!!!, obviously!!! sql express 2012 stop it!! "sql server setup is not supported in WOW64!!" of course!!, so i install sql express 2014 with independent installer!, then i have two errors with microsoft visual C ++, this issues make installer abort!!!.
please please i need your help, right now i have installed sql express 2014, i attach log file.
thanks a lot of.
have a nice day!!!.
ihayesjr
Sorry that you are having difficulty installing Vault Basic.  According to your log file, the installer is still installing SQL Express and can't.  If you installed SQL Express 2014 already, I believe that you did not specify the AutodeskVault instance name during installation.  I would recommend that you uninstall SQL 2014 Express Database engine and re-install it using the direction outlined in this article.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
